September 12, 2013 5:49 AM PDT
2007 HD SPORTSTER 1200C
I have a small leak at the adjuster in the clutch cable. I took it to a mechanic (Not HD) and he said I needed a new clutch cable. Even though I mentioned it may be that the primary vent is clogged. (Based on internet research). He didn’t pay much attention to that. So of course I pay for a new Clutch cable and 2 days later, leaks again. Long story short, I take it back again, he talks to some guys and he says primary vent is clogged. He tells me the cost to remove half the engine to get to it isn’t worth the cost, so I can just drill a hole in the back of primary and add a check valve so it can vent or just live with the small leak. Really?
So assuming it really is a clogged vent, can anyone help me with these questions?
1. The vent hose is attached by a clamp but is not very accessible. It’s nestled under the cylinder head and starter. Personally I don’t think the hose as any obstruction in it and I did use air pressure and a wire best I could to clear out hose. Is the vent hose attached to some sort of check valve and maybe that valve is clogged?
2. Any ideas how to remove and check or replace without dismantling engine or removing the starter?
3. I have looked thru my HD Manuel and on line and can’t really find anything by HD indicating this vent hose. Why?
4. So assuming pressure was built up in the primary and the clutch cable adjuster was the weakest point to release fluid, is the clutch cable seal blew out now?
Little background on my bike. I just bought it from a guy who bought it for his wife new in 2007. She never got into it, so it basically has been garaged for 6 years. It had 211 miles on it. Maybe since it sat so long the vent got clogged basically from lack of use and it’s a rare thing and that’s why I can find anything on it. Cause a 6 year old bike with 211 miles is a pretty rare thing.
September 12, 2013 6:09 AM PDT
Trans fluidly level ok could be to full if you can get to the vent hose probably stopped up as we call them dirt dobers just need to clean put the vent small wire will work not sure about check valve don't think so _
